Uporedne dimenzije vozila
bulex je napisao(la):
ej daki moze li porodjenje... izmedju actrosa 1848 i volva fh12 420 :D
i interesuje me fico i peglica... :D
hvala :D
MERCEDES-BENZ Actros
Engine
Type: V6, Direct Injection Diesel, 4 Valves per Cylinder
Displacement: 12 L
Horsepower: 235(320)/1800 hp/RPM
Torque: 1217/1080 lb-ft/RPM (1650/1080 Nm/RPM)
Driveline
Gearbox: Automatic Transmission, 12 Speed
Front Axles: I-Beam type
Rear Axles: HL6 with single reduction
Chassis
Suspension Front Axle: Parabolic leaf springs, double acting shock absorbers and stabiliser bar
Suspension Rear Axle: Full air with electric modulation, modulation acting shock absorbers and stabiliser bar
Brakes: Discs
Steering: Recirculating Ball, Power Assisted
Tires Size: 315/80 R22.5
Features
Model Availability Rigid 6x4, Tipper 6x4 and Gritter 6x6
Gearbox Manual Transmission, 16 Speed (Standard for 6x4 and 8x4 Models)
Rear Suspension Steel Axle - Two springs bogie, double acting shock absorbers and stabiliser bar; Parabolic Dual Rate Leaf Springs, Double Acting Shock Absorbers and Stabilisers (Standard for Gritter 6x6 Model)
Tires 385/65 R22.5 (Front), 11 R22.5 (Rear) - Standard for Gritter 6x6 Model
VOLVO FH 12.8L (400 HP)
Engine
Type: D13A400, 6 Cylinder in line, Electronically Controlled Injection
Displacement: 12.8 L
Horsepower: 294(400)/1400-1800 hp/RPM
Torque: 1475.1/1050-1400 lb-ft/RPM (2000/1050-1400 Nm/RPM)
Driveline
Gearbox: Manual Transmission, 14 Speed
Front Axles: 7.1t
Rear Axles: 13.0t
Chassis
Suspension Front Axle: Parabolic leaf spring with stabiliser and shock absorbers
Suspension Rear Axle: Road friendly air suspended drive axle with shock absorbers and stabiliser. Electronic controlled suspension regulation
Brakes: Discs
Steering: Recirculating Ball and Nut, Power Assisted
Tires Size: 295/80R22.5
Features
Model Availability 4x2 Tractor, 6x2 Tag-Axle Tractor, 6x2 Push-Axle Tractor, 8x4 Rigid
Cab Availability Day, Sleeper, Globetrotter & Globetrotter XL
Gearbox Manual Transmission, 9 Speed / Auto-Mechanical Transmission, 12 Speed
Tires 315/80 R22.5, 385/65 R22.5, 305/70 R22.5, 315/70 R22.5
Engine Emissions Euro4 & Euro5
Rear Suspension Non road friendly two spring design with parabolic leaves, shock absorbers and stabiliser. Front and rear spring to axle mounting with rubber cushion.
Ovdje se vidi da je Volvo kada su kamioni u pitanju u manjoj prednosti naspram Mercedesa
FIAT 500
Length: 116.9 in (2969 mm)
Width: 52 in (1321 mm)
Height: 52.1 in (1323 mm)
Wheelbase: 72.4 in (1839 mm)
FIAT 126
Length: 120.2 in (3053 mm)
Width: 54.2 in (1377 mm)
Height: 52.6 in (1336 mm)
Ovdje vidimo da iako imaju isti osovinski razmak, popularna Peglica je nesto duza od FICE.
