Prodajem pojacalo DLS
CA41 - 500 Watts 4-ch. amplifier
Cijena 200 KM
061 439 650
CA 41 is a powerful amplifier with power output of 4 x 70 Watts. With a mono bridge-connection, it puts out all of 200 Watts.
- Built-in/switchable low pass and high pass filters.
- Bass boost 25 Hz - 80 Hz 0-18 dB.
- Built-in protection circuits shut down the amplifier in the event of overloads.
- Hi level input with Auto start
Use it for a front system and a subwoofer.
- High level input with auto start.
- RMS output power @ 13,8 V, 20Hz - 20 kHz
Specifications
Number of channels 4
Amplifier class AB
Mono bridge mode 4 ohm 2 x 200 W RMS
Output power in 2 ohm 4 x 125 W RMS
Output power in 4 ohm 4 x 70 W RMS
Damping factor >100
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
Filters channel A & B HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10)
Filters channel C & D HP: 15-500 Hz / 150 Hz - 5 kHz (x10)
Grand bass filter 0-18 dB @ 25-80 Hz
Remote bass level control No
Low level output Yes
High level input with auto start Yes
Remote phase shift control No
Power consumption (idle) 0,7 A
Power consumption (max) 60 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 30 A
Dimension (W x D x H) 70 x 372 mm x 268 mm (2,92 x 14,65 x 10,55 inches)
Weight 4,2 kg ( 9,3 lb)
Cijena 200 KM
061 439 650
Specifications
Amplifier class AB
Damping factor >100
Fuses 2 x 30 A
